Interface Description Parsing
Librenms can interpret, display and group certain additional information on ports. This is done based on the format that the port description is written, although it's possible to customise the parser to be specific for your setup.
Keywords
See examples for formats.
- Keywords
Cust- CustomerTransit- Transit linkPeering- Peering linkCore- Infrastructure link (non-customer)- Info-keywords
()contains a note{}contains your circuit id[]contains the service type or speed
Examples
Cisco IOS / NXOS / IOSXR:
interface Gi0/1
descr Transit: Example Provider (AS65000)
interface Gi0/2
descr Peering: Peering Exchange
interface Gi0/3
descr Core: core.router01 FastEthernet0/0 (Telco X CCID023141)
interface Gi0/4
descr Cust: Example Customer [10Mbit] (T1 Telco Y CCID129031) {EXAMP0001}
Unix / Linux:
This requires an additional script to be setup
# eth3: Cust: Example Customer [10Mbit] (T1 Telco Y CCID129031) {EXAMP0001}
# eth0: Transit: Example Provider (AS65000)
# eth1: Core: core.router01 FastEthernet0/0 (Telco X CCID023141)
# eth2: Peering: Peering Exchange
Customisation
The following config options can be set to enable more custom types:
webui/port-descr
lnms config:set customers_descr.+ 'cust'
lnms config:set transit_descr.+ 'transit'
lnms config:set peering_descr.+ 'peering'";'
lnms config:set core_descr.+ 'core'
lnms config:set custom_descr.+ 'something_made_up'
Custom interface parser
It's also possible to write your own parser, the existing one is: includes/port-descr-parser.inc.php
Once you've created your own then you can enable it with:
webui/port-descr
lnms config:set port_descr_parser includes/custom/my-port-descr-parser.inc.php
Here is an example of a very simple file that parses type and descr.
<?php
return function (string $ifAlias): array {
if (! str_contains(':', $ifAlias)) {
return [];
$parts = explode(':', $ifAlias, 2);
return [
'type' => $parts[0],
'descr' => $parts[1],
Fields
Fields you can fill in your returned array
- type: port type (only defined types will show as graphs)
- descr: description of the port
- circuit: usually a circuit id
- speed: can be a plan name or a numeric speed 10G (or asymmetric 10G/500M), numeric speeds can used by custom maps and some graphs
- notes: notes
Variables
Variables you can request for your function include:
- string $ifAlias
- int $port_id
- string $ifName
- int $ifIndex
- \App\Models\Device $device
Device Setup
For Unix / Linux based systems, you need to run an additional script to support the parsing of interface information.
- Add
ifAliasfrom/opt/librenms/scripts/or download it from here to the Server and make it executablechmod +x /path/to/ifAlias - Add to
snmpd.confsomething like:pass .1.3.6.1.2.1.31.1.1.1.18 /path/to/ifAlias - Add aliases with
iproute2package like:ip link set eth0.427 alias 'Cust: CustomerA'-
in
/etc/network/interfacesor/etc/network/interfaces.d/*with a comment like:# eth0.427: Cust CustomerA -
Restart
snmpd-systemctl restart snmpd
There are no changes to be made or additions to install for the polling librenms.
Now you can set up your keywords in your aliases.
